Power Supplies
Discussion in 'Nintendo Wii-U & 3DS' started by ldoodle, Dec 19, 2006.
  1. ldoodle
    ldoodle
    Apr 2, 2005
    6,568
    +1,018
    Is the Wii power adapter bespoke, hard wired and region rated? I need to get a US Wii (all GC games are US), so need to know if I can just use a UK style plug and connect it into the transformer (or just cut the end off and refit with uk style), or if I need a step-down convertor.
    Thanks/...
  2. Vini
    Vini
    Nov 25, 2005
    1,611
    48
    UK
    +66
    its hardwired.
    adapter (wii) --> brick --> uk wall plug
    cant help with info re: stepdown etc...
  3. t-force
    t-force
    May 2, 2001
    1,878
    Southampton, UK
    +156
    You'll need a stepdown, as the US adaptor is only rated 100-120 Volts, which is a bit of a pain. You could try your luck to see if Nintendo UK would send you one (say it broke or something), or even sell you one.
  4. ldoodle
    ldoodle
    Apr 2, 2005
    6,568
    +1,018
