Power problem with Fujitsu 4214
Discussion in 'Plasma TVs Forum' started by too_laid_back, Mar 31, 2005.
  1. too_laid_back
    too_laid_back
    Sep 30, 2002
    38
    Essex
    Hi guys...
    I have an 3yr old 4214... that has started to power it's self off, for no reason. The power on switch is flashing amber. I normal fix this by switching the screen off for 30 secs, then power back on ok.. This prob works for a few hours, then back to the flashing amber light again.
    First thought it could be fuses or spikes, but i have changed all the plugs & put in an surge protector. :confused:
    Any ideas???... or contacts for an repair place for them to check... :lease:
    Thanks for the info guys!!!
  2. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    It's your power board, a repair is feasible, if you get a silly quote off Fujitsu, let me know, PM or something. I know a guy who is capable of sorting this.
  3. shisler
    shisler
    I too have a Fujitsu P42HHA10Es that has the on/off flashing. I bought in Europe and noe in the States and need a power supply board. Pretty sure that is the fix. Anyone had this problem and had it fixed?
