In general, no to both.Is it bad to cut the power to your amp at the power outlet switch instead of using the amps own power off button?
Could this damage the amp?
Most amps (please note my use of terms such as "in general" and "most") simply have a mechanical power switch before the transformer, and is electrically equivalent to having it outside the box. If you need a definitive statement for your specific amplifier though, you will have have to give some clue as to its identity. Alternatively, get hold of a service manual and look at the circuit diagram.Interesting to hear as my amp cannot be switched off with its remote control, so ive found some power adapters that can be switched off with a remote. I'll probably get my logitch remote to control the power outlet switch.
How's that for a long winded workaround!
Thanks for the reply, is there any info out there to back it up?
The M6PRE and M6PRX will be fine. Nice kit too.Musical fidelity pre and power M6 range
