Power out plug socket on avr3802
Discussion in 'AV Receivers & Amplifiers' started by Ash007, Feb 8, 2002.
  1. Ash007
    Ash007
    Dec 29, 2001
    217
    16
    Rochdale
    Does anybody know what type of plug plugs into the AV Power out on the 3802, and where can I get one. Is it a standard plug?
    Cheers,
    Ash
  2. Jase
    Jase
    Mar 16, 2001
    9,407
    South Coast
    +856
    Its a European 2 Pin plug like we have over here in Spain.
    I would imagine you could get one from a hardware electrical store or maybe they could order one for you.
    You could always do a search on the web for plug suppliers.
    cheers
  3. mja
    mja
    Ash,
    My 3802 came with this 2-pin plug already attached to the mains cable, and an adapter to turn it into a UK 3-pin plug. I just cut the 2 pin (and a bit of cable) off, replaced it with a proper 3 pin plug, and used the 2-pin and cable to connect my CD player through the AC outlet. Double check your plug to see if you have this arrangement or not - I assumed it was how the European model was shipped and that the UK importer (Heydon Labs?) added the 3-pin adapter.
    Good luck,
    Mark.
