Power lead plug - Hitachi PD3000
Discussion in 'Plasma TVs' started by jaminho, Oct 20, 2003.
  1. jaminho
    jaminho
    In a moment of witlessness i cut the plug off the power cable to my new plasma in order to route the cable behind plasterboard walls.
    I then read in the manual, do not cut off the cable as it 'may' contain some sort of radio interference blocker???
    Have i just messed up good style or will a normal plug be ok.
    Oh, by the way, as the length of the cable was touch and go when routing i cut it right up against the plug so i can't re-attach it
    I know, I know.... but what can i say.... I was excited!!!
    :zonked: :rolleyes:
  2. jaminho
    jaminho
    Anybody any thoughts,
    I was looking at getting everything up and running tonight
  3. Tim_UK
    Tim_UK
    Aug 13, 2003
    32
    would fit a normal plug - you can buy ferite rings from maplin that just slip over the cable to reduce radio interference if you are worried.
  4. jaminho
    jaminho
    Thanks Tim_Uk
    You never no, it may have been an issue
