Power lead for Toshiba, where from?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Bazel, Aug 7, 2003.
  1. Bazel
    Bazel
    Hi guys, moved rooms around a while back, went to set up the DVD player last night and guess what? The power lead has dissappeared into that big black hole that exists when you move things around, simple question really, can anyone advise where I can purchase one of these leads (or tell me the whereabouts of the black hole:D ).
  2. Mylo
    Mylo
    Mar 13, 2003
    5,541
    +372
  3. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,117
    83
    Over the Hill & Far Away
    +119
    Try a Mark Grant figure 8 cable.. very high quality for about £25 quid.
    Hes one of the member here.. well worth it!
    Matt
  4. gmt steve
    gmt steve
    Aug 19, 2002
    648
    Manchester
    +6
    How about one of Russ Andrew's very expensive cables?:p
  5. Bazel
    Bazel
    Thanks guys for the replies, popped up to Maplins and got one for £2.99:D
    Would love to get hold of a more expensive one to see if I could tell any difference though. Has anyone tried the same and found a massive difference that justifies the spend?
  6. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,117
    83
    +119
    yes.. I have a room full of DIY/Mark Grant and Russ Andrews cables. You could try a RA cable as it has a 60 home trial.. u don;t like it send it back for a full refund :)
    Matt
