Power lead adaptor?
Marktsafc
Hi, first post so hello all. I just bought a new 55" LG oled TV and been a bit stumped with it having a wired 3 pin plug already attached. My living room already had a 2 pin power lead wired in from my old Panasonic. Is there an adaptor that will solve this? I'm moving house soon so won't be digging into the wall. Many thanks in advance
ChuckMountain
No, because although you can remove a cover to get the LG power connector it is a 3pin connector with an earth cable that is attached.
If you only use the 2 pin lead it is not earthed and the new TV will not be correctly wired in.
If it's only temporary suggest that you just use an extension lead if the LG power cable isn't long enough to plug into a normal wall socket.
Podcast: Sony A90J Thoughts, madVR Processor & Sonus faber Lumina II Reviews + Movie & TV roundup
