Power DVD vs Theatertek player
Discussion in 'Desktop & Laptop Computers Forum' started by adesonic, Aug 12, 2003.
  1. adesonic
    adesonic
    Jan 28, 2003
    65
    Manchester
    Anyone got any views on the comparative strengths and weaknesses of these two players? I have Power DVD but am thinking of switching to the Theatertek player (based on some reviews) but owuld like some other opinions before I lay out the cash.
    Thx in advance
  2. paublo
    paublo
    Sep 2, 2001
    169
    South Lanarkshire
    Theatertek has superior image quality using the latest Sonic decoders.... it also has excellent HTPC type facilities for playing DVDS, like saving default aspect ratio settings and start position.
    Where it is let down, is via its dependencies on Microsofts interface code, which can cause problems. Fast forward/rewind is troublesome...
    Zoomplayer is an excellent alternative (but does not include filters), I personnally prefer and have purchased TT, but have friends who like the ability within ZP to select the Sonic video and powerdvd sound through the graph builder facilities... I also belive but have not checked the profressional version, which is near to TT is terms of facilities...
    Depending on your outlay on equipment, there is very little to be lost in trying out Theatertek, if you use a projector and want to create a cinema, remote controlled, full screen environemnt and dont need to play low quality avi's etc, then TT is the way to go in my opinion..
    I hope this helps..
    Paul.
  3. Madders
    Madders
    Jan 30, 2002
    2,316
    London
    +49
    Hi, I have both players but tend to run Powerdvd5 for the most part (mainly due to audio issues with my HTPC and soundcard/ amp. I think Theatertek is a great player, but I would also consider Nvidia 2.55 which I actually think has the best picture. You can download a demo for free to try this out!
    By the way Paublo, congrates on finally getting the HGS-18. I was gonna bid £1900 but decided I am not such an ar*s*hole, as you probably had to go cap in hand to 'er indoors to up your bid to £1800!! :D You're a lucky guy!!
    Cheers,
    Steve
  4. adesonic
    adesonic
    Jan 28, 2003
    65
    Manchester
    Thanks guys, I downloaded theatertek this evening and used it to watch Star Trek Nemesis- excellent picture quality - so far, I am very pleased
  5. paublo
    paublo
    Sep 2, 2001
    169
    South Lanarkshire
    cheers madders.... I am looking forward to the HGS....
    I hope it was worth the wait.. and stress for Nathan.... he appears to be doing better now... just a few more bits to go.. :)
  6. Donnacha
    Donnacha
    Jul 4, 2002
    7,408
    York
    +3,679
    I have both and prefer TT - but as I have a few SVCDs and VCDs I use PowerDVD for this. But for DVDs TT has better piccie quality and the aspect ration control is great for non-anomorphic dvds when using a projector as you can "expand" the image to fit the screen. I've had not regrets in buying it - but agree FF/FRW can be troublesome.
  7. paublo
    paublo
    Sep 2, 2001
    169
    South Lanarkshire
    why not try zoomplayer, building a custom graph? You can then have the benefits of the latest sonic bits and the ability to play svcd's etc..
    Paul.
  8. owenw
    owenw
    Jul 19, 2003
    269
    Ireland
    Guys,
    The M-Audio Revolution 7.1 sound card bundled with Theatertek (OEM) on www.digitalconnection.com for $129.00
    The soundcard goes for $89 on it's own so you're getting TT for 30 dollars. Is this a good price?
    Owen
  9. SeaneyC
    SeaneyC
    Jul 26, 2002
    2,004
    48
    Reading, Berkshire
    +54
    Yes.
  10. Donnacha
    Donnacha
    Jul 4, 2002
    7,408
    York
    +3,679
    Paublo, it sounds like hard work getting everything to run in Zoomplayer. I had a mess around with it before and it didn't do what I wanted at the time. Is the newer version better? Is it easy to build graphs?
  11. paublo
    paublo
    Sep 2, 2001
    169
    South Lanarkshire
    I havent used it since 2.90, as I dont want Svcd's etc.... it appears daunting to begin with, but the levels of customisation and support from their forum is excellent... worth the hassle IMO..
    I believe the newest versions have automatic graph builders.. I may go and have a play for a laugh... sad...
    Paul.
  12. Donnacha
    Donnacha
    Jul 4, 2002
    7,408
    York
    +3,679
    Might be curious myself and give it a go
  13. Gary Lightfoot
    Gary Lightfoot
    Apr 6, 2001
    12,479
    Surrey. UK.
    +2,123
    I would think using Zoomplayer with just PowerDVD should be simple enough - just choose it from one of the video/audio combinations and register the filters - all done with a few clicks of the mouse. Not sure if the later one comes with Sonic filters as a selection, but if you use TT and use the default, it may pick them up and use TTs vid/audio.
    Just a thought.
    Gary.
