Power DVD settings
Discussion in 'Desktop & Laptop Computers Forum' started by m0v1em4n, Nov 11, 2001.
  1. m0v1em4n
    m0v1em4n
    Jul 1, 2001
    833
    Derby
    +49
    Hi all,
    Could some one please tell me what the video mode should be set to in Power DVD
    BOB or WEAVE or AUTO-SELECT.
    steve
  2. Jenz
    Jenz
    I leave it at auto-select. But Hardware Acceleration MUST be Off.
  3. m0v1em4n
    m0v1em4n
    Jul 1, 2001
    833
    Derby
    +49
    Thanks Jenz,
    Which of the following do you use to complement the DVD software?
    YXY , POWERSTRIP or perhaps both,
    are they any more i should be looking at?
    Just trying to set-up a HCPC to go with my Barco 708 data and i am a complete novice, so any pointers would be gratefully accepted :confused:
    Steve
  4. Jenz
    Jenz
    For the Barco 708 you should use a sweet spot of 800x600 and have 2 memory blocks configured.
    Mem Block 1 for Anamorphic
    Mem Block 2 for 4:3
    You should make sure you can run your Adapter on the PC at 72 & 75hz at 800x600.
    If you can you do not need to use Powerstrip.
    If you'd prefer to use one memory block on the Projector then use an Anamorphic one and then use YXY to rescale the non-anamorphic stuff you may have.
    Jenz.
  5. m0v1em4n
    m0v1em4n
    Jul 1, 2001
    833
    Derby
    +49
    Thanks Jenz,
    My video card is a nVIDIA GEForce2 MX 400 AGP, 64meg,
    So if I set the desktop to 800x600 x72hz for NTSC and changed it to 75hz for pal, then I would not need powerstrip?
    Should I use a Anamorphic test pattern from Avia to size the image? Then use memory block 2 and size that for 4.3 images?
    Would this be correct? :confused:
    Sorry for all the question:)
    Steve
  6. Jenz
    Jenz
    Correct. Powerstrip really comes into its own when you need to have total control over the refresh rate and aspect ratio which I suspect you don't.
    For the Anamorphic Mem Block yes. Making sure that the projectors Vertical height is reduced to match the 16x9 image. This is often termed an Anamorphic Squeeze. Its using the full projector raster to show the image.
    Yes correct.
    Regards Jenz.
