Power DVD 4.0 help please
Discussion in 'Desktop & Laptop Computers Forum' started by Phil Hinton, Sep 17, 2003.
  1. Phil Hinton
    Phil Hinton
    Editor Staff Member
    Jan 18, 2001
    10,090
    3
    +7,966
    For reviews I like to put the discs through Power DVD 4.0 and by checking the information it gives the kbps rate for Dolby and DTS. However my copy of Power DVD does not display dts, it says it is unavailable. I have downloaded a trial version of Power DVD 5 and this feature works on it, but my trial is over and I am back to version 4, and again it wont show it.
    Any ideas? Can't find version 5.0 in the shops. And the download is £40 which I don't want to do.
  2. nathan_silly
    nathan_silly
    I'm pretty sure my Power DVD 4 does display the dts bitrate!
  3. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    IIRC the DTS support is in an add-on module ... if you go to their website they tell you how to check the version you have, OEM versions are often 2-channel mode and of course DTS needs 6-channels.
    I could be marking up the wrong tree here, it's some time since I had the basic 2-ch version.
    Also, as I read their website the upgrade from V4 to V5 is $29.95, which is what I did some time back when V5 was released.
  4. Phil Hinton
    Phil Hinton
    Editor Staff Member
    Jan 18, 2001
    10,090
    3
    +7,966
    It's an OEM version, two channel dam!!
  5. Phil Hinton
    Phil Hinton
    Editor Staff Member
    Jan 18, 2001
    10,090
    3
    +7,966
    Anybody help any further? Dont want to spend £40 just for one feature. I only use the PC for review stuff, have a scaler and player for the PJ.
  6. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
  7. nathan_silly
    nathan_silly
    Ask Spectre to buy a full license for ya?
  8. Kramer
    Kramer
    DVD Shrink will show the audio bitrate IIRC.
    Good news is.........
    It's free :clap:
    :p :p
  9. Phil Hinton
    Phil Hinton
    Editor Staff Member
    Jan 18, 2001
    10,090
    3
    +7,966
    It doesn't does it. Just downloaded and it shows full bitrate at 1,010mb, but full rate is 1.536mb is it not? Or am I missing something.
    EDIT: Ignore my last I knw get it.
    Many thanks Kramer
