power cut ,player on stand by
Discussion in 'Blu-ray & DVD Players & Recorders' started by j.fitz, Jun 19, 2001.
  1. j.fitz
    j.fitz
    hi had a power cut during monday night with power flickering on and off for several hours [acording to neighbours]while dvd player[pioneer 626d]was on standby.have checked fuse on plug and this is ok.is there another internal fuse conected to power supply and if so is this a standard item regards jimmy.
  2. General Skanky
    General Skanky
    Jul 28, 2000
    4,253
    71
    Colchester
    +44
    If it's stuck on standby I'd bet it's blown a couple of fuseable resistors in the power supply.
    The internal fuse, if blown, would only give you a dead unit.
    So, it's a workshop job unless you can fault find the duff components!
