Power consumpton
Discussion in 'Microsoft Windows' started by ADENCOOL, Oct 19, 2005.
  1. ADENCOOL
    ADENCOOL
    Jul 14, 2003
    77
    does anybody know how much power is being used when a pc is s3 state
    is it full power or does it require just a few watts
    (just want to know this so i can work out how much it will cost to leave in s3 mode)
  2. mark.carline
    mark.carline
    Jan 15, 2004
    2,132
    Chester, Cheshire
    +121
    Does this mean that you wont be able to record any scheduled recordings if you leave it in S3 mode ???
  3. meansizzler
    meansizzler
    May 11, 2005
    7,892
    104
    London
    +343
    Yes you will, the pc will wake up from S3, record and go back to sleep
  4. Werner
    Werner
    s3 is a very low power mode, the pc is practically running from your +5v standby current on the power supply, which is normally only rated at a few amps at most. v=i x r would give you about 5-20 watts at most (assuming 1 amp to 4 amps on the +5v standby rail). Nothing to worry about..it may as well be off.
  5. mark.carline
    mark.carline
    Jan 15, 2004
    2,132
    Chester, Cheshire
    +121
    I suppose sombody could use an ammeter that could be used to measure the power usage ??
    I have also tried to use S3 for recording with limited suucess, 1st scheduled recording just failed completely and 2nd recording turned the PC but didnt switch it back to standby. - Anyone here using this with 100% success rate ?
  6. meansizzler
    meansizzler
    May 11, 2005
    7,892
    104
    London
    +343
    I switched to S3 yesterday, works fine for pc...woke up from standby and recorded two shows succesfully. not tested the feature to go back to standby after recording yet...
  7. rdhir
    rdhir
    Jul 31, 2005
    471
    Glasgow
    +8
    from another thread, the trick for standby is the time taken to go to standby in the power settings in control panel. Set it for 5mins
    Rajiv
  8. mark.carline
    mark.carline
    Jan 15, 2004
    2,132
    Chester, Cheshire
    +121
    ...I see so MCE will wake up to record but what puts it back into standby is nothing to do with MCE but the normal windows power control panel settings.
    Is this right ?
  9. Werner
    Werner
    *nods
    correct
  10. meansizzler
    meansizzler
    May 11, 2005
    7,892
    104
    London
    +343
    that is not a good solution, as when I defrag my hard drive five minutes into it it goes into standby...
  11. mark.carline
    mark.carline
    Jan 15, 2004
    2,132
    Chester, Cheshire
    +121
    Hm..
    When its in this S3 standby mode will the NIC, IP address and IIS (web server) still be running ?
    I use WebGuide3 and want that running 24x7
  12. rdhir
    rdhir
    Jul 31, 2005
    471
    Glasgow
    +8
    nope.
    If its standby the machine is dormant.
    But you could set it to wake-on-lan. WOL.
    This is a lot easier if the network connection is on the motherboard as you need cables and headers for a network card.
    The only thing I'm not sure of is whether its a special network command to Wake it Up or if a simple http: request would suffice.
    A secondary problem might be that if it comes out of S3 how much time does it take.
    Rajiv
    Whats the obsession with the WATTS anyway. Its about 2 lightbulbs worth of power?
  13. meansizzler
    meansizzler
    May 11, 2005
    7,892
    104
    London
    +343
    I tried the same thing myself, I set my network card to use standby power
    control panel>system>Hardware>device mnager>your network card>Power management>"allow device to bring computer out of standby"
    Anyway got that working, but whenever I loggedinto webguide when the computer wa in standby the computer never woke up, so webguide never worked, i've not used wake up on lan before, so don't know how I go about setting it, there is no jumped on my motherbaord for it, nad in the bios there is a "wake on link" setting is this the same as "wake up on lan"
  14. mark.carline
    mark.carline
    Jan 15, 2004
    2,132
    Chester, Cheshire
    +121
    interesting I have this in my config :
  15. mark.carline
    mark.carline
    Jan 15, 2004
    2,132
    Chester, Cheshire
    +121
  16. rdhir
    rdhir
    Jul 31, 2005
    471
    Glasgow
    +8
    yup wake on link is the same as wol.
    I think you need that setting "allow to bring out of standby."
    I think step 2 is to find how to create the frame or magic packet.
    When WOL is used in corporate environments its usually with software that's got an agent on the machine, so it wouldn't surprise me if there is a magic packet or frame. But it maybe someone's got a simple executable to create (a bit like a ping). anyway you have now exhausted the extent of my knowledge. Do let us know if you get a solution.
    Rajiv
  17. mark.carline
    mark.carline
    Jan 15, 2004
    2,132
    Chester, Cheshire
    +121
  18. mark.carline
    mark.carline
    Jan 15, 2004
    2,132
    Chester, Cheshire
    +121
  19. Werner
    Werner
  20. mark.carline
    mark.carline
    Jan 15, 2004
    2,132
    Chester, Cheshire
    +121
    Ok - Got the patch now - We'll be trying it tonight and i'll post on here if it works.....
  21. mark.carline
    mark.carline
    Jan 15, 2004
    2,132
    Chester, Cheshire
    +121
    Yep this utility generates the "Magic packet" but we need the "Wake up Frame" which (i think) is an ICMP / Ping request.
    I've managed to get ahold of a laptop for the weekend so i'll be trying the acid test of using WebGuide3 connected via port 80 and then waiting for the PC to go into standby S3 and then clicking the refresh button and seeing if the machine wakes up / services the http request and then goes back to sleep again!
    Utopia !
  22. mark.carline
    mark.carline
    Jan 15, 2004
    2,132
    Chester, Cheshire
    +121
