Power consumption among formats
Discussion in 'Headphones, Earphones & Portable Music' started by ESP, Jul 1, 2005.
  1. ESP
    ESP
    Does anyone if one compressed format versus another consumes more power?
    I have the Sony 1GB NW-E107 flash player which claims upto a 70 hour battery life on 1 AAA battery. The fine print however mentions its under conditions playing ATRAC3 @ 105kbps. This leads me to believe that different formats (MP3, ATRAC3plus...) and even different rates have different power consumptions.
    I only have my player half full with MP3's and ATRAC3plus @ 64K. So space isn't really an issue and I would re-rip my CD's at ATRAC3 @ 105kbps if it meant my battery would last longer. But if the power consumption difference is negligable, then I wouldn't bother. As for quality, I'm not a stickler as I can't tell the difference between MP3's and ATRAC3's or ATRAC3plus' at various rates on a noisy bus or subway.
    Thanks!
  2. darkdashing
    darkdashing
    atrac is less than mp3, check out the new nw-hd5. 40hours per charge if atrac, 12 if mp3
  3. L11
    L11
    Jun 2, 2005
    323
    +7
    12 if mp3? are you sure you dont mean 30?
  4. darkdashing
    darkdashing
    Its on par with the ipod from reviews i've read (when using mp3s)
  5. Chox1988
    Chox1988
    Mar 30, 2005
    16,792
    basingstoke
    +9,157
    As far as I know the lower the bitrate the longer the battery lasts. More compressed formats last longer than none compressed so ATRAC etc will last longer than MP3.
  6. Linkable
    Linkable
    I get 30 hours out of it easily with mp3 @ 192kbps. I think you are mistaken with the model as the battery of the HD5 is one of it's main advantages over the iPod.
    As for formats, I used to convert all my files to ATRACplus 64 for a while, mainly for having more space with about the same quality but I stopped converting for two reasons. The quality was less in more complicated songs (with sometimes a bit of hissing, haven't had that with mp3's) and because the converting took aaages! I think you could manage through 1 Gb but 20 Gb just takes too long.
    I can't say anything about playing time though, except that my HD5 will play 40 hours on ATRAC 32 and it does 30 on my mp3 @ 192kbps.
  7. exalnt
    exalnt
    all my ATRACS on my HD5 are in 256K format and it went almost flat yesterday and i had to charge it for the FIRST TIME since the night i got it... which was 4 weeks ago....
    damn i love my HD5 :D
