power cable problem
yzfr6rocket
can anyone help as you know some lcd tvs when turned off only go into standby
(which my wife hates and the reason for the post) is there a safe way of putting an on/off switch into the cable, as our plug sockets are hidden behind a false wall and to get to them means moving a heavy piece of furniture
thanks in advance
smjxm09
I also use mine to control the table lamps in my lounge. I have used double sided tape and placed the remote next to the light switch. The maplins one is better value as you get 4 sockets rather than 3 from Argos.
When you get the unit you will assume that the left hand buttons turn things on while the right hand buttons turn things off. Actually the right hand buttons don't do a thing while the left hand buttons turns the product on and off.
Podcast: Sony XH95 TV, Klipsch The Fives Speakers & Bias Light Reviews + Best of the Month
