Power Cable for SVS Sub
Discussion in 'Subwoofers' started by the thing wnn, Apr 29, 2005.
  1. the thing wnn
    the thing wnn
    Sep 1, 2002
    3,674
    Brecon Beacons
    +510
    Hi all,
    I have hopefully got my new PB12-Ultra coming in the early part of May (fingers crossed). I realise the power cable supplied comes with the two prong eartless plug on it. I have a fairly good lead at work from a spare TFT screen which has a 5A fuse in it. My question is, is this lead suitable for the Sub? It has the standard kettle end that fits the sub ok from pictures i have seen of the amp. I was mainly concerned about the fuse. Is 5A correct?
    Thanks in advance for the help
    Cheers :thumbsup: :confused: :)
  2. Pollywoggle
    Pollywoggle
    Aug 14, 2000
    1,442
    South Shropshire
    +81
    My svs subs have 5amp fuses. You can use the lead you indicate, on one of mine I just cut the US plug off and put a 5amp fused UK plug on instead.
  3. Mroizouk
    Mroizouk
    Jan 11, 2005
    333
    London
    I used a computer lead on mine, the thing. Your lead should be just fine.
  4. the thing wnn
    the thing wnn
    Sep 1, 2002
    3,674
    Brecon Beacons
    +510
    cheers all, can't wait!!! :devil: :)
  5. Dfour
    Dfour
    Jan 19, 2004
    3,998
    71
    Bracknell
    +85
    I built myself one based on the sids posh power cord specs. Seemed to make a small difference over a standard cable to my ears.
