power cable for a wall mounted plasma?
Discussion in 'Home Cinema Buying & Building' started by jtf, Mar 21, 2005.
  1. jtf
    jtf
    Nov 19, 2004
    220
    colchester
    +7
    i am going to be wall mounting my pw7 soon and i'm a little confused as to how to connect up the power cable to the socket. do i extend the cable and plug it in with everything else or do i join it directly to the mains socket that is on the wall below where the plasma is to be mounted or am i on totally the wrong track.
  2. GiZZeRR
    GiZZeRR
    May 24, 2003
    Edinburgh
    I fitted mine like that but used a plate with fuse fitted.
    John
  3. jtf
    jtf
    Nov 19, 2004
    220
    colchester
    +7
    GiZZeRR which option are you replying to?
  4. GiZZeRR
    GiZZeRR
    May 24, 2003
    Edinburgh
    Sorry JTF, my cable wasn't long enough but I had a longer one which I cut the plug off and I wired it straight into a surface mount fused switch. only a few pounds from B & Q :smashin:
    John
  5. jtf
    jtf
    Nov 19, 2004
    220
    colchester
    +7
    thanks john.
