Ugg10
First post in this section (plenty in photo and hifi) so hoping someone can help.
I am having work done on my house and there is a possibility I may have to have it re-wired so this is not good but does present some opportunities.
The main opportunity is to fit CAT5 around the house.
I am on VM for everything so have a cable Ethernet router/wifi. My plan would be to extend the cable incoming wire up the side of the building into the loft where I can put the wireless router (may be able to do a test to see if coverage is OK beforehand using a long extension. From there I can distribute the CAT5 cables to probably 4 or 5 rooms/points. The wires can be pulled through with the power cables if I need to change those.
Ideally I would like a double socket faceplate with two CAT5 or one CAT5/one usb charger socket(s) in the standard size double plate. I have seen the double sockets with home plug integrated into them and also with USB charger points but non with power and Ethernet.
Can Anyone point me in the right direction to find one of these or confirm they do not exist.
Alternatively, most rooms have a double coax cable from the loft servicing both aerial and satellite signals. Most of these are not used. So is there an "Ethernet over Coax" solutions that I could use to feed 4-5 sockets from the router. This may be in the form of - VM cable > router > Convert CAT5 to coax > coax to loft > "some sort of distribution box" > coax to rooms > convert back to CAT5. Is this possible and viable in terms of speed/stability/cost (less hassle) ?
Sorry for all of the questions, just trying to scope out my options.
Thanks in advance.
Thanks in advance.
