Question Power amplifier for B&W 683s2 using Denon X3400H
gazza01
I have had these speakers for a few months, I heard them at a show and bought a pair second hand, my room is not very big 4m x 5m, I listen across the shortest length, they are in the corners of the room pulled out 250mm from the walls, I can not put them anywhere else as it is my living room and they are a good sized speaker and my wife is already a bit miffed about their size. The Denon is an AV amp and quite warm sounding, in surround they sound great but with stereo I like a cleaner sound, without using Audyssey they sound very warm without too much punch, the Audyssey helps quite a bit but I would like a cleaner sound with more definition, I used to have an Audiolab 8000p amp but unfortunately sold it before getting these speakers, I would like to keep the speakers and find a power amp to help get the sound I am after, after suggestions. I don’t hate the sound, I generally enjoy it but think it could be better.
Ugg10
Rotel and B&W are often paired together, possibly because they are now part of the same group, but this may not apply to the older models. The rotel RB power amps can be picked up quite cheaply second hand and have good power supplies and most of the older ones can be bridged to use as mono blocks (only 8 ohm speakers though) at the flick of a switch (and connecting the speakers correctly). I had a pair of RB850's used with B&W CDM1SE's mono blocked (150W each) and this was a really nice set up.
The gem in the older series tends to be the 100w/channel into 8Ohm (200w/4ohm and 300W/8ohm bridged) RB870BX with its fully dual mono design (one circuit board per channel), large toroidal transformer and 20,000uF per channel but can tend to demand a price premium (but still a reasonable £150ish).
Rotels tend to be fairly neutral and generally have good power supplies so can handle dynamic swings pretty well.
You could also look at the RMB1066 (around £200-300 second hand) that gives you 6 channels of 60Wx6 or you can bridge the channels for 150Wx3 (8 ohm only) so you have the option to use this for your whole surround sound setup or just the fronts.
Finally, if you can get your hands on a RB1070 or even a RB1080 then this would provide a good bit of umph for the B&W's. (the later RB15xx series are quire a bit more expensive)
HOWEVER ....... generally the power amp has a lesser effect on sound tone/quality than the preamp section of the music chain, so if you are still using the Denon for your stereo sources then this may be what is causing your issues. You can look to get an integrated with HT bypass and then connect your stereo sources to that thereby removing the Denon form the chain. This is the usual way of adding stereo sources to the front speakers for stereo listening.
Orobas
Very much agree with Ugg10 on this one.. Rotel is an ideal partner for B&W and given their sound characteristics .. get's my thumbs up
gazza01
Thanks for the informative reply, I will keep my eye open for the amps in the normal places, the HT bypass could be more like the better answer, although I am unaware of this option, I will have a google.
Ugg10
Another to look out for would be the Quad 606/707/909, these are all derivatives of the Quad Current Dumping topology and are rated at 140w per channel and have power in reserve.
The 606 is typically around £400, the 707 doesn't come up often and the 8909 being the newest is usually around £500 mark (all second hand).
Orobas
Quads are quite a bit more coloured than rotels though Ugg10 .. not quite as neutral.
Ugg10
Agree but mainly in their Preamp’s, less so in the power amps, I think these are the best of the bunch and will drive most speakers well.
Rotel and Audiolab are probably the best of the bunch for neutrality.
Be useful for the OP to give a budget and new/second hand direction.
Orobas
I'd concur with just the addition of one other.. the Cambridge Audio 851W power amp.. this thing is a beast of gem... sonically wow but erring very warm tonally and at some £800 more than the 909 is a heart clutching proposition... I'd usually point at the roksan but they do not partner well with B&W .. they show too many weaknesses with the b&w's
gazza01
To be honest, I have not really thought about a budget, I was after advice on if it would improve the sound, it would have to be second hand and ideally around £200, I was unaware that the pre amp would have such a significant effect on the sound, so I am unsure of which route to take.
Orobas
At that budget.. i'd say you'd have to stick with the rotel option... i am not sure, and hoping Ugg10 might be able to shed some light on this.. if a NAD power amp would be suitable for one of their higher end stuff 2nd hand as they tend to be cheaper than rotel.. say their... 214 which you can pick up for around £180 these days
Ugg10
I’ve only had experience with a Nad preamp (1240) which I fed the rb850s with. It had a very good phono stage but tone wise it boosted the bass but lacked control, all a bit flabby especially compared to a the Rotel RSP1066 which was a surprisingly good stereo preamp/dac or my passive preamp (mpatch v2). Not sure about the power amps but the 216 (iirc the model number) got decent reviews.
£200 would get you a good condition 870bx if one comes up or possibly an 8000p that you used to have.
Orobas
Thanks Ugg10 .. never been too sure what to make of the Nads! it was just the price that made me think of them. but thanks for the heads up. helps me out for sure for future :)
just looked up the 216 and yeah i think we can leave the nad out of the equation.. described as a clunker.. bright and bass heavy
Ugg10
This would probably do the job if you are close enough to collect. RB980BX, 120w per channel into 8 ohms, 20000uF per channel.
Review - http://www.rotel.com/sites/default/files/RB-980BX HPreview 92.pdf
gazza01
Yes the 870bx or 8000p seem like good choices but I am now concerned that my Denon AVR will have too much influence on the sound? I’m guessing the only way to be sure is to buy one try it, or would I be better with a 8000s or something similar but worried it could be a little under powered?
Ugg10
There is a couple of “cheats” that can be done.
Ideally you would have the surround sources (satellite, dvd, blueray, tv etc) connected to the avr and the rear, centre and sub running off that. To the front pre-outs you connect an integrated stereo amp via the ht bypass input. Into the stereo integrated you then connect stereo sources (cd, tuner, cassette, turntable streamer, dac etc.). In surround mode you set the integrated to the bypass input which turns it into a power amp, re run the room eq / surround setup and use it normally as an avr. For stereo turn off the avr and use the integrated with the stereo inputs.
Unfortunately stereo amps with ht bypass tend to be the upper end models so are expensive.
However, with non ht bypass integrated you can either get a speaker switch (two in one out) to switch the input to the front speakers between the avr and integrated, or set up as above and return the volume control to the same point (where set up/calibrated) when using the avr, easier if you have a digital volume display in either dB or numbers.
The rotel ra03 is a bit of a sweet spot in the newer integrated or the ra1060/1062 would be good if you can find one at the right price.
This option open things up a bit but will depend on what sources you use.
gazza01
Thanks for the suggestions, I will consider my options, I realise that the speakers are likely too big for my room but am sure it can be remedied partly by a neutral amplifier.
Ugg10
You can always play around with bunging up the port with rolled up socks to try and tame the bass. Originally iirc they came with foam port bungs for this.
gazza01
HeHe, I do have the original bungs, I initially needed them, but since moving the speakers it appears I dont need them, but could be worth another look.
b1g1an
I've just added a power amp to my 3500 and the results are excellent, although it's a 5 channel bought because the amp was struggling running 7 speakers, the change in 2 channel music run in Direct mode is amazing. My R300s have really come to life, much bigger soundstage, more detail... More musical!
Others have reported the same adding power amps to Denon AVRs with power hungry speakers even though popular opinion is it's the pre amps are most at fault as stated above.
gazza01
Hi which power amp are you using?
gazza01
I am a fair bit happier with the sound of my system at the moment, I pulled the speakers further out from the corner around 70mm, probably the furthest I can get them out the corner without them looking silly and upsetting my wife any further, I re ran the Audyssey set up and it improved the sound, I have found I prefer listening with the Audyssey MultEQ xt32 on but without the dynamic EQ on, the bass is controlled without any boom and better imaging, I still will likely add an amp of some sort to try to improve the dynamics.
LG CX 4K OLED TV Review: The best TV of 2020?
Trending threads
Latest News
TV licence fee now applies to over 75s from 1st Aug
  • By Andy Bassett
  • Published
New H.266 video codec promises 50 percent data saving
  • By Andy Bassett
  • Published
Toshiba launches UL20 4K HDR TVs from £299
  • By Andy Bassett
  • Published
LG GX soundbar launches in UK
  • By Andy Bassett
  • Published
Sky Q updates smart features and adds Disney Plus in HDR
  • By Andy Bassett
  • Published
