Power amp???
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by StAnToN, Jul 2, 2003.
  1. StAnToN
    StAnToN
    Oct 5, 2002
    514
    28
    +33
    Hi M8ys
    ive currenlty got a Pioneer 2011 receiver and was entertaining the thought of getting a power amp do you think its worth getting or shoul i just stick with just the Pioneer 2011 on its own??
    im using Kef Q Series speakers and was thinking about a Rotel power amp?
    thanks
    StAnToN
  2. Steve.EX
    Steve.EX
    Oct 17, 2001
    3,161
    68
    +69
    Stanton.
    A good power-amp will indeed serve you well, the Pioneers have something of a reputation for being slightly "weak" when put under stress.
    Adding a power amp will bring several benefit's to include, even tonality when things get rough, improved bass definition and a general openess to the sound-stage, not to mention improved 2 channel stereo performance.
    Adding a power amp to an integrated A.V unit is a common path that most enthusiast's end up taking, to add a processor to the power amp at a later date.
    Pretty much anything from Arcam, Audiolab, Musical Fidelity, Roksan, Rotel, Tag will bring definate gains at moderate prices.
    Regards
    Steven.
  3. jhjerpe
    jhjerpe
    Mar 1, 2003
    701
    2
    28
    North London
    +58
    Slightly different approach, I added a A85 intergrated stereo AMP to improve music, this also has the side benefit if removing the need for the 2011 to drive the front L&R's and also open ups the path for changing my L&R to 4 ohm speakers.
    My next upgrade will be to bi-amp the fronts and then eventually move to a processor / power amp setup (space allowing).
    Adding the A85 gave me more benefits for the money IMO than just adding a 5/7 chanel power amp.
  4. pwiles1968
    pwiles1968
    May 15, 2003
    773
    Leicestershire - England
    +9
    Do you Just want a 2ch amp for front speakers to give gains in stereo or are you after a multi channel?
  5. StAnToN
    StAnToN
    Oct 5, 2002
    514
    28
    +33
    im after a multi chanel power amp i was thinking something along the lines of a Rotel RB 985 but im not sure if its gonna be worth it any ideas power amp whats a good one to go for?
    thanks
    StAnToN
  6. pwiles1968
    pwiles1968
    May 15, 2003
    773
    +9
    Marantz did a multi channel power amp MM9000 which has only just disappeared from their web site it is a 5 Channel 140 Watt THX Approved unit, and it has Variable Gain for each input (via potentiometer next to RCA input) the reason this is good for you is that you can adjust the gain so it is the same as your 2011 and Bi-Amp up to five of your speakers. It was designed to complement the AV9000 (£2000 when new), so it cant be a bad amp, and it is flexible enough to last you a while. I have seen these for £650 http://www.hifibitz.co.uk/warehouse/details.asp?ProductID=MARMM9000 Marantz Recommended Retail was £800.
    It’s only a suggestion but it is an amp that is often overlooked and I can vouch for the sound quality of the Marantz power stuff
    :smashin:
