Question Power amp suggestions? Crescendo DIY Power Amp Thoughts?
Discussion in 'Hi-Fi Stereo Systems & Separates' started by GPaschakis, Sep 11, 2017.
  1. GPaschakis
    GPaschakis
    Apr 11, 2017
    Edinburgh
    +7
    Hi Everyone,
    i was wondering if anyone has any experience with the Crescendo Millenium (Mosfet) power amp? I found one and the seller is willing to sell it for 190 pounds plus delivery which prob it will be about 50. At the moment I'm using a DIY gain-clone power amp but is producing a humming noise that drives me around the bent. Plus I recently changed my speakers to the MA silver 6s and the 45w doesn't do them justice. The only problem is that I want to keep the cost below 300 pounds for at least 80w.
    Any thoughts?
  2. BlueWizard
    BlueWizard
    Jun 19, 2007
    22,133
    +4,163
    Curious, what is the rest of your system? If you have a Power Amp, you must have something functioning as a Pre-Amp to feed it, and you must have some type of Source to feed the Pre-Amp.
    If you want Maximum value in amps, consider the Behringer A500 Studio Reference Class-A/B Power Amp which are about £175 with 125w/ch to 8 ohms. The amp can be Bridged, so for stereo it would take two of the amps, buy you would have 375w/ch to 8 ohms.
    Behringer A500 Amplifier - Product Detail - Studiospares
    Behringer A500 Reference Amplifier at Gear4music.com
    Z Review - Behringer A500 Power Amplifier
    Power Class: Class AB
    Watts/Side @ 8 ohms
    : ... 125W RMS/175W Peak
    Watts/Side @ 4 ohms: ... 185W RMS/300W Peak
    Watts Bridged: ............... 375W RMS/600W Peak
    General YouTube Reviews of the Behringer A500 Studio Amp -
    YouTube Search - Behringer A500
    That is a very popular amp at a fantastic price.
    Steve/bluewizard
  3. BlueWizard
    BlueWizard
    Jun 19, 2007
    22,133
    +4,163
  4. GPaschakis
    GPaschakis
    Apr 11, 2017
    Edinburgh
    +7
    Hi Steve,
    Thank you for your recommendation. I will definitely have a look!
    My current set up:
    Gainclone DIY power amp 2 x 45w @ 8 Ohms
    DIY Pre-Amp based on Musical fidelity xd10 (valve)
    Cambridge Audio 640p phono stage
    Cambridge audio 640v2 Cd player
    Rega P1 record player
    Sumiko Blue point 2 Cartridge
    Monitor Audio Silver 6
