Power amp recomendations
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by timz_1222, Jun 29, 2004.
  1. timz_1222
    timz_1222
    Hello im thinking of getting a power amp and 2 500 watt speakers for me room (jus 2 defen ppl) i would like a set up that plays quite good quality music. i wish 2 spend around £600 and wud like sum recomendations :)
    thanks alot! :thumbsup:
  2. mjn
    mjn
    May 24, 2001
    22,069
    Herts, England
    +9,812
    well, for a start...wattage isn't everything.
  3. nikyzf
    nikyzf
    Wattage for speakers is pretty meaningless. Is that peak or continuous, and what is the efficiency?
    Volume AND quality for that money is asking a lot. I'd see what Richer Sounds have. NAD and Rotel make good powerful budget power amps. BTW what are you using as a preamp?
  4. timz_1222
    timz_1222
    hmm i dunno yet i was going to look into that l8r... do u recon its worth waiting and spending more on a amp?
  5. nikyzf
    nikyzf
    You need some sort of preamp in order to select source, control volume, etc.; power amps don't do that.
    Yes, if you want quality that you will be happy with for a while, you need to spend more. What is your source BTW? CD or vinyl, you need a good signal or the rest will be a waste of money.
  6. CrispyXUK
    CrispyXUK
    Feb 5, 2003
    3,742
    71
    Land of the Living, Essex
    +37
    P.M.P.O lol, imagine the size of a real 500W 2 channel amp :)
  7. nikyzf
    nikyzf
    I think there's a Krell or 2. Into 4 ohms, that is :eek:)
  8. CrispyXUK
    CrispyXUK
    Feb 5, 2003
    3,742
    71
    +37
    sure its not 2ohms? :)
  9. CrispyXUK
    CrispyXUK
    Feb 5, 2003
    3,742
    71
    +37
    just re-read original post! wants 1k for £600 lol, mate as wattage is pretty meaningless I'd look into getting a second hand rotel pre and power you should be able to get 80+80 watts of musicall lovlness for that money
  10. nikyzf
    nikyzf
    Hence my earlier message :eek:). Rotel and NAD make good value high power amps. Speakers are also part of the budget...
    Some Krells will drive 1 ohm loads, but I guess you know that.
    "There are 10 kinds of people in the world: those who understand binary, and those who don't" ;o)
  11. CrispyXUK
    CrispyXUK
    Feb 5, 2003
    3,742
    71
    +37
    1 Ohm! :eek:
  12. nikyzf
    nikyzf
    Not relevant to the original question, but see
    http://www.stereophile.com/amplificationreviews/266/
    It all seems a bit much really, when people like Linn can produce world-beating sound from small boxes that don't require a direct feed to a power station ;o)
  13. vizslaraner
    vizslaraner
    Dec 13, 2003
    487
    Hereford
  14. nikyzf
    nikyzf
  15. alexs2
    alexs2
    Nov 13, 2002
    13,957
    +1,671
    Indeed they will....try 100W into 8 ohms,and doubling all the way down to 800+W into 1 ohm...the KMA's I have will do this,but some of the newer ones are "only!" good down to 2 ohms....off topic,but fun nonetheless.
    The best of all for sheer grunt was probably the old MDA300,which would pull off the same stunt all the way up to about 2.5kW.
    I would also say that in terms of value for money and power,the Rotel amps take a fair bit of beating in all their price ranges,and NAD are also worth a look.
  16. vizslaraner
    vizslaraner
    Dec 13, 2003
    487
    Hereford
    And I was unashamedly following the derailment to suggest there's more to sheer grunt than Krell.
  17. timz_1222
    timz_1222
    thanks all!! ive read all your sugestions and there r sum cool amps in some of the recomendations!
  18. nikyzf
    nikyzf
    And then you'll want some speakers. In case you didn't know, having more efficient speakers can be much more effective than having a more powerful amp, especially as your speakers might not like accepting double (or whatever) the power.
    A few basics: if you double the power, this is only a 3 dB increase; to get a subjective doubling in volume, you need 10 dB more, which is 10 times the power. Speaker efficiency is rated in dB for 1 W. Choosing a 90 dB speaker instead of an 87 dB one will give the same volume increase as doubling amp power from say, 50 to 100W.
