power amp on side
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by CYRUStheVIRUS, Mar 8, 2003.
  1. CYRUStheVIRUS
    CYRUStheVIRUS
    Jan 25, 2003
    1,304
    41
    Brighton
    +14
    can i put my ROTEL RB985mk11 on its side,is there any reason why this might damage it, does anyone currently do this, help missus is moaning :nono:
  2. sounddog
    sounddog
    Dec 11, 2002
    3,370
    107
    Leicestershire, UK
    +461
    The only reason I can think NOT to do this is that with it flat, most of the weight (of transformers, caps, etc) is supported by the chassis underneath, whereas on it's side there will be more twisting forces involved.
    And of course the blue smoke has different accoustic characteristics in capacitors on their side.
  3. nathan_silly
    nathan_silly
    Not forgetting heat dissipation. The hot air will not rise out of the slots, instead it'll rise to the right side/left side.
    Nudge, nudge, wink, wink- so no more! :D
