Power Amp Dilema!
Kazman
In the opinion of the wise people here, which would be a better solution.
Two stereo power amps and a monobloc, or a 5 channel power amp?
Does a decent 5 channel power amp have the ability to supply constant, stable, effortless power to all channels as well as seperate stereo or mono power amps?
Dobieman
The ability of any amplifier is largely due to the power supply. Well designed multichannel amps will have headroom in this department to feed the circuits. Obviously mono amps have a power supply per channel though some one-box amps use this topology. To get an idea of an amplifiers performance under load, check out all channels driven figures against single channel figures. If the difference is huge you can tell that the power supply is perhaps under stress at times.
If money is no object then indeed 7 high current amplifiers would be my choice though this would require dedicated circuits and extremely good ventilation.
Great solutions include Rotel, Nad, Primare, Arcam, Classe, Tag, Bryston, Chord, Krell, Levinson.... all using variations on the topology.
Ultimately it boils down to size of room and power required. There is a "house sound" to take into account ensuring compatibility with your other kit. Oh and BUDGET!!
Kazman
Thanks for that matey :)
This is the next step for me, and it won't be until later this year anyway.
I'm thinking either Parasound or Rotel, just wondering which house sound would work best with the Quads. I like a warm side of neutral type sound, and overly bright amplification really doesn't appeal to me.
Budget will be between £1500-£2500, might stretch it if the equipment is worth it.
Reccomendations? Current size of room is 10mx4.5m, but, this will change when we move house, which we intend to do in the summer hopefully.
R
Roam
Warm side of neutral sounds like NAD would suit well, going on my C320BEE amp experiance anyways. The T973 beast has seven channels of 140 realistic watts (probably underrated) and you may be able to biamp your fronts if using 5.1 if it's possible to configure your pre-outs that is (maybe tricky). One for the shortlist!
isko
I recommend Rotel. I am using RMB-1075 (5ch power amp) of Rotel which has genuine 800 watt transformer. It has a cyristal clear net sound even in very high volumes no hiss at all.
Dobieman
Have listened to:
Parasound Halo A51 (5) - slightly warm sounding but very powerful amp (250W)
Arcam P7 - (7) very detailed, musical amp but lower powered than Parasound (160W)
Rotel 1075 (5) - the best entry into high end separates though rounded at the frequency extremes (120W)
Nad S250 (5) - good clean amplifier though no longer available (125W)
Musical Fidelity M250 - great mono amps - bags of power and usual MF cleanliness (250W)
Tag 100:5r (5) - clean but a tad clinical (mechanical) to my ears
Bryston 9B ST (5) - superbly built, bombproof truthful amp though only 120W P/Ch
Musical Fidelity A3.2 * 3 - wonderfully musical amplifier, would need three for 5(6).1 system (130W)
Linn 5125 (5) - sweet sounding amp from one of Uk's best loved (125W)
There are many, many more to suit budget but given your speakers and room I would look at 3 * MF A3.2 power amplifiers for the best of both worlds! Do DEMO any kit as I can't stress enough the impact of room acoustics and partnering kit - good luck!
Kazman
Thanks for all the help guys, gives me a starting point to go from.
I do like the appearance of the Parasound Halo A51 (very WAF which is also an important factor, the SVS was my last WAF veto token), will definitely look at the Musical Fidelity too. I'm more concerned with quality of sound rather than outright power, so not fussed if the power rating per channel are low, just as long as they can sustain that power without difficulty.
No one has mentioned Primare, how do their products rate against what has been mentioned above?
Philly112
My wife didn't break out into an uncontrollable grin when it suddenly appeared in the house
Phil
Kazman
My wife isn't bothered about things being large ;)
She actually thinks the SVS PC Ultra looks 'cool' now :D She will love the blue light on the power button.....easily pleased :D
R
recruit
Kazman - The A51 is Big but the power is truly massive and you can sense it or should i say feel it in the room, when i heard Rags it was absolutely effortless.
Brilliant Amp :thumbsup:
dynamic turtle
Unless plug sockets are in short supply, you can't go wrong with monoblocks. They're the ultimate in flexibility terms too. Otherwise, 3 stereo power amps. The "spare" channel should be just that, in case you upgrade to 6.1 one day.....
Loads of good amps listed above, except:
Copland CVA535 (5 channel, 125 wpc, £2000). Lovely jubbly!
Audio Analogue Donzetti Mono's (£525 each). Good value.
Crimson 640 Mono's (200W, £650 each)
Primare A30.5 (£1700)
Roksan Caspian 5 Channel (£1300)
DT
liamjf
Anywhere in London where you can dem the Parasound amps?
Liam.
marck
I used to own the Copland CVA 535 and was very impressed with it. Just that the upgrade bug hit, and I changed it for a Krell - but then it all comes down to budget! Well worth a listen to though.
avanzato
Well as it's a config that's not been mentioned yet I have a 2 channel and a 3 channel power amp. They're Consonance Opera C-200 & C-300 which look very much like the hegel H series amps but in black, not sure how deep the similarities go. TBH I'm not sure if they are still available as I got them Ex-Dem direct from the distributor Alium Audio
I feel they are neutral in character with very high build quality and there's no problem driving my 4ohm Jamo THX speakers with the wee beasties (actually they're flippin big). The 2 channel does Left/right and the 3 channel does the rest.
Kazman
I heard some Roksan Caspian mono's on Saturday, they were fabulous!! http://www.avland.co.uk/roksan/caspianpowerm/caspianpowerm.htm
Anybody else heard these? Only 100watts each, but, the sound was lovely, effortlessly driving some Tannoy Sensys floorstanders. The speakers were probably not doing the amplification justice though, but the sound was certainly impressive.
How would these compare to the Primare or Parasound amps mentioned above? And the Rotels of course :D.
rags
Kazman,
As your not to far you more than welcome to come down and hear the Parasound in action. I am waiting for my new speakers and sub to arrive but they should be here in a few days. Whilst I have not heard the Roksans you can forget the Rotels. Good amps for the money but the Parasounds are better (I used to own a Rotel 1095)
Kazman
rags said:
Kazman,
Excellent :)
PM when you get your new speakers matey :)
lovegroova
Just to add that I preferred the Rotel 1095 to the Parasound - horses for courses really, they are both very good indeed.
Daneel
To which Parasound?
Latest News
Starzplay streaming service rebrands as Lionsgate+
  • By Andy Bassett
  • Published
JVC adds Filmmaker Mode to latest D-ILA projector firmware
  • By Andy Bassett
  • Published
Bowers & Wilkins launches Px8 headphone
  • By Andy Bassett
  • Published
Sky set to launch its plug-and-play Sky Stream solution
  • By Ian Collen
  • Published
Movies Podcast: 26th September 2022
  • By Phil Hinton
  • Published
