Power Adapters, Surge Protection and Mains Conditioners
Discussion in 'Cables & Switches' started by jamezm, Sep 15, 2007.
  1. jamezm
    jamezm
    Aug 18, 2005
    1,076
    48
    Fareham
    +34
    Can these really make a difference to picture / sound quality? Has anyone got a particular recommendation with a budget of £20-£50?
    I recall seeing an adapter advertised that is one sealed unit that plugs into a standard power outlet and splits into a 4-gang adapter without a trailing cable (i.e. it just plugs in and the 4-gang adapter sits above or below the regular outlet), this would really tidy up my AV area, and it includes surge protection. Anyone know where to find these? (can't find ad now!)
    Thanks in advance
  2. JohnWH
    JohnWH
    Jan 23, 2004
    1,826
    48
    St Albans
    +82
    In theory a conditioner will make a difference if you have clearly apparent problems with mains bourne interference. You do need to be careful though, sticking things like this in the feed to a power amplifier could introduce additional resistance which may effect its perfromance when under heavy load.
    As far as improving PQ is concerned, if you have a fully digital chain (DVD->HDMI->LCD/Plasma) then claims of PQ improvement, particularly sharpness, colour etc, from fitting conditioners etc are extremely questionable.
    Cheers,
    John.
  3. bsimmer3000
    bsimmer3000
    Aug 25, 2006
    760
    +24
