Potntial setting up problems with new Z4 or similar
Discussion in 'Projectors, Screens & Video Processors' started by chestnut, Oct 23, 2005.
  1. chestnut
    chestnut
    Jan 27, 2005
    59
    I'm considering buying the new Z4 subject to how it's rated against the competition. I just need a little guidance on the set up. The room i'm using is 3.6 x 4.6m. The projector will be sited opposite a 3 seater futon shooting across the width of the room (3.6) onto a pull down manual screen. Ideally I would like to mount the pj onto a unit approx 900mm high next to the futon which would require the image to shift at least 1.3m to the right or left to produce the image on the screen centrally to the seating. The question; Is the lense shift capable of achieving this at a good viewing height?
    Any help would be grateful.
    Chestnut
