wiknerhacker
When i wall mount a forthcoming 506xde, all of the plugs to the appliances - tv/vcr/dvd/sky/pio media box will be plugged into a 5-plug bar that will sit within the fireplace. the power cable from this 5-plug bar will then be routed behind a skirting board, along with a lead that i presume is the outside aerial??
if i change to sky+ and then to sky HD when it comes out, will a different aerial lead be used ie. will i have to unattach the skirting board? and also, are there any other wires that should be running to the mains or outside other than the ones i've mentioned. i'm sensing a classic 'passing the point of no return' scenario when i try and bodge it...
TIA
Luke
TIA
Luke
