Potential speaker setup
Discussion in 'Home Cinema Speakers' started by jag, Aug 21, 2002.
  1. jag
    jag
    I am currently thinking of a setup that would have the KEF Q1's as FL, FR and Center. And then the KEF Eggs as the Rear Speakers.
    Does this sound like a reasonable combination to have? Reason being I have more space at the front than at the back.
  2. Jase
    Jase
    Mar 16, 2001
    10,724
    United Kingdom
    +2,501
    Certainly sounds reasonable to me. Top them off with a decent sub and you´ll have a great system.:)
  3. jag
    jag
    Such as my Velodyne CHT-10 ;)
  4. jag
    jag
    Also, are the Q1's available as single speakers yet or just in pairs?
  5. Jase
    Jase
    Mar 16, 2001
    10,724
    United Kingdom
    +2,501
    Ah yes! forgot you had one of those!:D
    Don´t know if the Q1´s are available as a single unit yet, how about emailing Kef?? Here´s their website KEF
  6. Lowrider
    Lowrider
    You will have problems with the eggs mix, not only timbre matching, but particularly crossover matching, 80hz for the Q1s, 120hz for the eggs...
    Well, it will not be the end of the world loosing some bass of the surrounds, but male voices will sound thin from the back...
    No way to fit Q1s against the back wall... :confused:
