Can anyone give me an imbeciles guide to running Qobuz on Roon through the 1120 please? Specifically if I can set volume levelling using Roon, as Qobuz does not offer it.
I’ve had enough of waiting for Spotify to join even the cd rate offerings of others.
Download Roon to your PC, Mac or
NAS and setup the 1120 (
which is listed as Roon Ready) under
audio settings, then hopefully you can select that zone and play to it. For a basic Roon setup that's all you need to do.
If using a PC or Mac just select ‘use local core’ for now when prompted - more on this below.
It should hopefully be obvious, but if you need help enabling your Qobuz account in Roon
this guide should help.
You can then additionally install the
Roon control/remote app on your phone/tablet and point it at your
Roon Core running on your PC, Mac or NAS if you’d rather control Roon from a mobile device.
btw. In case it’s useful
this link / code gets you an extra 30 days added to your Roon subscription for new signups.
For a smoother life down the road, assuming you stick with Roon, you ideally want a computer/device that can run the Roon Core (server) 24/7 — which problay isn't your PC or Mac. You also want that computer/device
connected to your router via ethernet — see below for why.
For the best experience, maintenance and support I'd get a used Intel NUC (an
older used Gen 7 or 8 model is fine -
suitable models listed here) and install
Roon's own ROCK OS on it which comes pre-installed with the Roon Core (server) software – it's basically DIY
Roon Nucleus for a fraction of the price.
Then hide it out of sight next to your router, hopefully in another room. That way the '
headless' Roon Core running on on the NUC will be ready to play music 24/7 to any
Roon supporting audio output device using any
Roon control app without you having to first boot up your Mac or PC.
If you have already started using Roon on your Mac or PC (with a local Core) simply create a backup, then connect to the new Core running on the NUC and
restore the backup from there.
You can then delete and reinstall the desktop app, skip the setup of a local Core and instead just point it at the remote Core running on your NUC. With this configuration the desktop app is just acting as a remote control and an audio output/endpoint. If a fresh desktop install doesn't completely remove your old local Core you
can also remove the old library / database files from your Mac or PC manually, this will ensure you only have one Core / Library running on your network.
You might also want to take a look at these two articles:
This
Roon KB guide may also be useful in terms of understanding the three key components of Roon's architecture —
Core,
Control and
Output. In short you can only have one Core, but you can have multiple Controls and Outputs.
You ideally
want the machine running the Core connected to your router via ethernet — this is where a lot of users running a local Core on a WiFi connected laptop run into issues when first using Roon — as the Core both retrieves and then decodes the audio before sending it out to
RAAT (Roon Ready) endpoints as uncompressed PCM or DSD data which is more bandwidth intensive than a compressed FLAC stream, especially if you have multiple hi-res streams playing to different endpoints at once. This is another reason why running the Roon Core (server) on a dedicated NUC (
ROCK) directly connected to your router via ethernet is the way to go.
The standard PC and Mac Roon apps include all three components (in one package) and can be setup to either run and use a local Core
or alternatively point to a Core running elsewhere on your network — this would be the case if you installed the Core on an NUC or NAS and just wanted to use the Roon app on your PC or Mac as a remote control.
The latter is how most people end up using Roon long term, as waiting for your your Mac or PC to boot up in order to play music isn’t much fun — but to start you can run Roon with a 'local core' enabled on your Mac or PC to get a feel for whether Roon is for you.
