Postcode checker - to be relied on??
Discussion in 'Satellite TV, Sky TV & FreeSat' started by mobily, Jan 27, 2004.
  1. mobily
    mobily
    Dec 30, 2003
    504
    Plymouth
    +3
    Hello all,
    I am moving in 3 weeks and have put the postcode of my new place on the freeview website, and it say that I will be unable to receive freeview signals.
    Has anyone else had this problem and then purchased or tested a freeview box and found that they can actual receive pictures?
    I am planning on purchasing the pioneer DBR-TF100GB but don't want to be disappointed if I can't get a picture.
    The place I am moving in to is rented accommodation, so if the landlord won't let me install a new aerial on the roof, should it need one, can you get a decent indoor one?
    So many questions! :)
    Thanks for all your help,
    James
  2. richgtfc
    richgtfc
    Feb 14, 2003
    129
    19
    Edinburgh
    Don't just rely on the postcode checker. If the aerial's crap you'll struggle. I had to manage with an indoor aerial and booster and it was 'OK' just, but had to constantly fiddle with it. Drove me mad:mad:
    Rich
  3. mobily
    mobily
    Dec 30, 2003
    504
    Plymouth
    +3
    I'm hoping that the landlord will be an accomodating man and shall allow me to install an outside aerial if the current one isn't good enough.
  4. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,379
    Somewhere in South Yorkshire
    +5,765
    Use the postcode checker as a guide only. Minor variations in geography can have a HUGE effect on the quality and strength of signal obtainable from a given transmitter.
    A decent local aerial man will be able to be more specific.
  5. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    According to the post code checker I can't get DTTV.
    However I have for over 4 years, so ignore the checker and see which transmitters you can use.
    Example Sutton is a digital transmitter so if you can get analogue off Sutton, you can get digital off Sutton
  6. Bl4ckGryph0n
    Bl4ckGryph0n
    Sep 11, 2003
    35,579
    5
    16
    CyberSpace
    +10,372
    I couldn't get it according to the postcode checker...Was only able to get some channels with a Panasonic box I borrowed...I purchased the Humax FOX-2 and now get all channels with 100% quality....Try it with either the Humax of Philips box which tends to be a bit more sensitive then some of the others...
  7. NX3
    NX3
    Dec 4, 2002
    3,492
    103
    +8
    The postcode checker says I can't get Freeview.
    The local tv man says I can't get it.
    It works perfectly.
    Best advice is borrow a box and try it :D
  8. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    Perhaps they want the Sky commision!
  9. STOWITBELOW
    STOWITBELOW
    Nov 17, 2002
    1,611
    48
    Lancashire
    +51
    Neigbours or local Tv type shop (if they sell digital) should know. A local buisiness wont want you b******* & moaning their goods don't work & should have experience. Ask about, & try one out to be sure. The postcode checker is a guide only.
  10. THAD
    THAD
    try using the postcode checker from the digital terrestrial television site.
    www.dtg.org.uk
