post office scale scam
Sleepy
Before i go to the post office to send a parcel i check the weight on some kitchen scales to get an idea of the cost.
I have been a bit suspicious that they have rigged the scales because It always ends up being slightly over at the post office so that you have to pay for the next price bracket.
So Today i decided to make a note what my parcel weighs (just under 500g) on my scales and on the post office scales 539g
has anyone else noticed this at their local post office and is there anything that can be done about it?
Phil57
...........and when, may I ask, were your scales last calibrated?
ben2579
That always happens to me - but I assume it's my crap kitchen scales and then being a little over the top with Sellotape! But Would love someone to test them with a weight!!
Phil57
put the marker on 0 and then reset it.
So you haven't had it calibrated then?
I'm not trying to be awkward, but if you are comparing your set of scales to another and are indicating that the other is wrong, you need to be absolutely sure yours are in perfect working order. I'm afraid you would have great difficulty in doing that.
liveforav
Buy a bag of sugar, take it home and weigh it.. you never know the supermarket may be adding extra to the bag to compensate for your post office losses ;)
The Dark Horse
Yes you need to weigh something that is a known weight on your scales, like a bag of sugar. Saying that I am always suspicious of airport luggage scales abroad. I remember one holiday my bag was heavier coming home even though I had used loads of toiletries, sun creams and left behind magazines I took with me.
Sleepy
I have checked with a 400g can of Heinz Tomato soup.
Come out just a little over (because of the weight of the can)
Sleepy
Coins are a set weight, get 20 2p coins which should weigh 7.12g each and weight them on your scale. If it's not 142-143g your scales are out.
Just done the coin test and it is showing 163g
so my scales are out by 20g
The post office scales are out by 59g
John7
watch out, because the "new" 2 p coins are made of steel now (check em with a magnet). Don't know if they are heavier or lighter than the old ones though?
NorvernRob
The best thing to do is get your scales independently calibrated by weights + measures (trading standards), this is what the PO will have to have done every so often.
Though i'm guessing your non-professional kitchen scales will quickly start giving iffy readings again.
Weighing equipment in use for trade - Trading Standards Institute
Fwiw I check stuff too, on a set of weight watchers digital scales and they're always within a few grams of the two different PO's I use.
IronGiant
You can't do it like that as kitchen scales won't be linear. You need to weigh 500g of coins to get even close to deciding whether they are accurate or not.
I can save you the bother though, they won't be :)
Phil57
You need to do a series of test weights, try 40x2p coins, then try perhaps 80x2p coins. (by the way 2x1p coins weight the same as 1x2p coin)
By the way this is NOT calibrating your scales, this will just tell you how poor your scales are.
You will NOT be able to calibrate the scales.
Yaka
Every post office have test Wieghts provided by the company that calibrates the scales for Post Office LTD. just ask the clerk if he or she can check the scales for you.
All post offices are audited very VERY strictly and the auditors check the scales with both the post offices weights and thier own.
Also if the office in question was trying to scam you they would have to reverse the postage stamps through the system then print a new one out, Post office ltd would pick up on it fairly quickly and investigated it and prolly pressed charges against the postmaster/clerk
your best bet is go to 1 post office, ask them to weigh it, make a note of weight, then go to your post office and see if they get same weight, theres a hefty fine by weights and measures if they do find shops with faulty scales
rousetafarian
Who really is bothered about this, what are we talking, pennies?
Similar threads
The Best Movies and TV Shows Coming To Amazon Prime Video in August 2020. Tom's Thumbs.
Latest News
Linn announces Majik DSM digital streamer upgrade
  • By Andy Bassett
  • Published
Sony announces WH-1000XM4 noise cancelling headphones
  • By Andy Bassett
  • Published
McIntosh launches C22 Mk V preamp and MC1502 power amplifier
  • By Andy Bassett
  • Published
Marantz unveils 12 Series Special Edition models
  • By Andy Bassett
  • Published
Samsung Galaxy Note 20 smart phone models launched
  • By Andy Bassett
  • Published
