Is there any difference at all in the following set ups?
Setup 1:My dining room has 4 cat 5e cables running from TV, PS3, amp & Sky into a cupboard which has a switch which then goes into the router.
Setup 2:My living room will soon have very similar equipment but instead of running 4 cables back to the cupboard with the switch I thought I would have all the equipment plugged into a switch and then just one cable running back to the cupboard with the router!
The only difference I can see is Setup 2 will have 2 switches. Will this create any problems?
If there are no obvious problems, why is it recommended to run several cables to each room rather than just one and use a switch apart from to send HDMI from room to room?
Steven.
Steven.
