In the past twelve months I have noticed on My Panny Series 4 42" Plasma, that vertical lines, such as tall building door frames etc., tend to bend over like walking stick handles, in the top 100mm of the screen. This is apparent from an old Sky+ box, also from a Pace freeview. The input to the scaler is RGBS from the SKY box, and it outputs to the plasma RGBHV, through a two way unit, the other feed going to a Barco CRT 7. This appears to be OK, and feeds from the DVD 32R are also O.K. on both the plasma and the CRT. I also get the error message 'No TAG link detected', using MD on the AV192R on the SKY and EXT DAB on the Pace inputs. The problem is intermittent, and is sometimes worse than others. I am HOPING that it is a fault with the Plasma, as that is to be replaced in 2007.
Anyone got any ideas
