Possible to use a 6th speaker with 5.1 films?
Discussion in 'AV Receivers & Amplifiers' started by Cheng, Feb 1, 2003.
  1. Cheng
    Cheng
    Dec 19, 2002
    374
    +6
    I have just installed a 6th speaker with my amp, a Yammy v630, I would like to know if it would be possible whilst playing 5.1 films to play something out of the 6th speaker,i.e. a combo of the 2 rears?
    Thanks,
    Cheng
  2. mandlebrot
    mandlebrot
    Aug 21, 2001
    426
    16
    Manchester, UK
    Yes the amp supports supports the center rear for Dolby Digital EX material so it should have some sort of mode to use it when only receiving 5.1. Just check, I'm sure it will have a psudeo 6.1 mode somewhere.
  3. mjn
    mjn
    May 24, 2001
    17,602
    Herts, England
    +4,518
    why?
    If the yamaha amp already has 6.1 speaker connections? Surely the Yamaha amp can use a DSP to take advantage of the centre rear. We all know how fond Yamaha are of the DSP's.
  4. GaryG
    GaryG
    Nov 20, 2002
    744
    Shropshire
    Sorry chaps, mis-understood the question, my reply was how to add a rear centre speaker in a 5.1 setup that didn't have support for the rear centre (a pseudo Dolby EX).
  5. mandlebrot
    mandlebrot
    Aug 21, 2001
    426
    16
    Manchester, UK
    No problem Gary, I had assumed that what you were saying and of course your solution could work with a standard 5.1 amp.
  6. EvilMudge
    EvilMudge
    As GaryG has requested I have removed all information that may cause damage to anyone's amplifier. My apologies if anyone feels I have edited their posts unfairly.
    For those with 5 channel amps, be advised that wiring up a single speaker to the positive outputs of the rear channels may cause the protection circuit to kick in, as the amp will register a link across two points that never normally get connected.
  7. GaryG
    GaryG
    Nov 20, 2002
    744
    Shropshire
    The 'Haffler' connection above was general advice, I now regret posting it as it's shifting the focus of this thread. If anybody is thinking of trying this you will need to consider the correct impedance for the rear speaker to avoid damaging your equipment. Generally speaking the impedance needs to be 2x the rated impedance for that channel, so for an amplifer that expects 8 ohm impedance the rear speaker will need to be 16 ohms or two 8 ohm speakers connected in series.
    Can a moderator please delete my initial response and follow up and also edit the subsequent quotes?
