Possible to upgrade Pioneer media receiver?
Discussion in 'Plasma TVs' started by sean in singers, Sep 12, 2005.
  1. sean in singers
    sean in singers
    Sep 4, 2004
    I have a Pioneer PDP-434HDG, which has one HDMI in connection, which I currently use from my Denon 2910. I am considering buying a mini mac to use for internet/music/photos, and wish to connect it to my plasma. The mini mac has DVI out, I believe I can buy an AVI to HDMI converter, but given the HDMI slot is already occupied, I don't know how to set it up.
    I see the newer Pioneers ship with 2 HDMI connections; is it possible to upgrade my current media receiver? Do I have any other alternatives that would produce a good picture?
    Confused...
  2. yellowpostit
    yellowpostit
    Jun 27, 2005
    177
    19
    Nottingham
    can you get a DVI to VGA, and use the VGA on the front flap?
  3. Alan A
    Alan A
    Jul 7, 2004
    186
    16
    You can buy one out two in splitters now
  4. sean in singers
    sean in singers
    Sep 4, 2004
    Thanks guys, both good suggestions. How much better will the quality be between VGA and HDMI? Also, with the splitter, how would you toggle between the feeds? Is there a priority channel?
    Cheers Sean
