Possible to turn pv500 on - straight onto AV1?
Discussion in 'Plasma TVs Forum' started by Stampax, Aug 16, 2005.
  1. Stampax
    Stampax
    May 6, 2005
    1,408
    Northampton
    +88
    I find it really annoying when i turn on my Panasonic pv500 that it goes onto a blank screen - I dont have an aerial plugged in, so no freeview, as I have sky. Thus I have to turn it on, and then press to go to AV1 for sky.
    Is there a way to turn it on so it goes straight onto sky???? Am i missing something really obvious, and this is gonna get stupid post of the year award????
  2. morganog
    morganog
    The stupid post of the year award goes to----Stampax!!!!!
    Congratulations!!!
    Go into the set up menu and select power up settings to AV! as simple as that...
  3. av2diefor
    av2diefor
    You are too easily annoyed stampax, time of the month? :)
  4. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,883
    Galactica C.I.C.
    +280
    :offtopic: Bit strong that, dont you think? The idear of asking a question is because you dont know the answer. What would be stupid is to know you have a problem, but not find the solution. :lesson:
    Also,
    When the Tv is turned on, even if you have the power on prefrence set to AV1 , in order for it to auto select , there must alreaday be a signal going to it.
    So if for example, if sky digital is connected to AV1, it must actually be on and not just in standby, for it to auto select on power up. :)
  5. Stampax
    Stampax
    May 6, 2005
    1,408
    Northampton
    +88
    cheers mate- knew it would be simple!!!!
    DAVE-S - he only called it stupid as i refered to it being a stupid post in my original thread.......
