possible to setup my DVD recorder so it records from freeview ?
jamieuk23
Hi just wondering if it is possible to setup my DVD recorder (kiss 558) so I can record from freeview ??
If so do you no the method of connection I will need to use ?
thanks for help !
Starburst
I would assume a simple scart cable will do the job.
A Freeview box is just another external source and as long as you tell the DVD recorder what input you are using and if it's RGB/Composite you should be fine.
