possible to get Component/RGB signal from Sky Digibox?
Discussion in 'Sky Digital TV Forum' started by Dwayneburke, May 21, 2004.
  1. Dwayneburke
    Dwayneburke
    Is it possible to get Component/RGB signal from Sky Digibox?
    Are there any devices i can use to run my sky digibox (not SKY+) and run it with decent signal to my projector as the composite is just not doing it
    Do sky+ plus offer any facility for this?
  2. gmt steve
    gmt steve
    Aug 19, 2002
    648
    Manchester
    +6
    Get hold of a JS.Tech rgb2YUV converter, that will give an excellent quality signal. They are available from the Sponsor's section.
  3. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    Tou have the ability to run RGBs via the scart. If you get a good video processor, it will be able to accept this and process it to whatever resolution. This will be the best picture short of modifying the sky box.
    ad
