Possible to convert Phillips DVDR75 to -RW ?
Discussion in 'Blu-ray & DVD Players & Recorders' started by PeteInYork, Oct 19, 2004.
  1. PeteInYork
    PeteInYork
    Oct 19, 2004
    14
    A long shot I know, but is there any way of converting a Phillips DVDR75 so that it can do both + and - ??
    I plunged for DVDR75 with +RW, but now have a requirement to record stuff so playable via portable -R player
    I wasn't sure if there was any sort of crack / mod that could be done
    Pete
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,877
    Warwick
    +2,791
    Afraid not. Your stuck with DVD+RW and DVD+R. You may find that DVD+R plays on your portable. Although it has significantly less compatibility than DVD-R it does play on many DVD players.
    If you have a PC DVD burner you could always use DVD Decrypter to extract your DVD+RW/+R and then burn to DVD-RW/-R.
  3. PeteInYork
    PeteInYork
    Oct 19, 2004
    14
    Thanks for the reply.
    Problem solved - I tried the Phillips + recording in the - playing Venturer portable & it worked OK - without any finalizing.
    Quality not as good as a bought DVD, but it'll do for a 6-year old
    Pete
