possible to attach sub via azur 640C/A?
Discussion in 'Subwoofers' started by ScoobyDoo69, Sep 5, 2004.
  1. ScoobyDoo69
    ScoobyDoo69
    hey guys, i have a cambridge audio 640A and 640C, and was wondering if its possible at all to be able to attach a Subwoofer to it? i wouldnt want to take the bass from my speakers, just have that EXTRA punchy bass and such, is this possible?? cheers
    ScoobyDoo69
  2. cribeiro
    cribeiro
    Nov 2, 2002
    2,809
    A Spaniard in Germany
    +308
    I do it via the pre-outs.
  3. ScoobyDoo69
    ScoobyDoo69
    so do u just choose any preout or both, i didnt think subs have a stereo input do they? or am i dense? lol thanks
    ScoobyDoo69
  4. Ian J
    Ian J
    Aug 6, 2001
    25,529
    +4,905
    Don't you have high level (speaker level) connections on your sub that can be attached to the speaker terminals on the amp
  5. cribeiro
    cribeiro
    Nov 2, 2002
    2,809
    +308
    Ian J, I think he doesn't want to use the speaker-level connections,
    "i wouldnt want to take the bass from my speakers", he said.
    Sorry, my solution is not universal... But almost.
    I assumed you have an active subwoofer. If so, then I think it must have two line-level (like from the cd player to the amp) inputs. That is what I use.
    If it is not an active subwoofer, I think you are not going the "wise way"... I think! I am not sure, but I believe it is highly reccomended... Correct me if I am wrong, Sub-Masters :)
    If you only have one line-level input in the sub(maybe home cinema in-a-box are like that, assuming you'll connect the sub-output of the amp), you might join both pre-outs with a Y connector, that should sum the signals up and deliver them at the sub-input. I don't know if you could damage the amp by doing this, but it sounds safe to me.... Any comments on this?
  6. Ian J
    Ian J
    Aug 6, 2001
    25,529
    +4,905
    A speaker level connection would feed the sub with a full range signal but the sub's crossover would be set at the point where the bass in the main speakers would start to roll off so that it would not take anything away from the speakers but continue where they left off.
  7. cribeiro
    cribeiro
    Nov 2, 2002
    2,809
    +308
    That sounded like text book!
    I know that, but I assumed he is concerned about the quality of the signal. The use of crossovers degrades it, in any case. If it is a good one, it might be unnoticeable, but I think this is rarely the case (I don't know it). In any case, after checking the quality of my (Magnat alpha A30) sub's crossover (I can hear voices through it when set to 50 Hz, although very low), I wouldn't dare to use it for my stereo system (also Azur 640 A&C). Maybe I am wrong?
  8. avanzato
    avanzato
    Jan 21, 2003
    1,954
    Norfolk
    +77
    Most subs do have a stereo input but not all of them do, check before you buy.
