Paul D
I have came across a possible fault with my S3 projector.
When in high contrast mode(fine in normal mode), i can see faint horizontal lines running across the image.
I first thought it was a DVI issue, but it is on all video signals.
I have done the normal battery of tests...
Different DVD player
Different plug socket
Progressive/interlaced
DVI/Component
Different discs.
High/Low lamp mode.
It is more noticeable in the bottom righthand corner, with the Iris in high contrast mode(F5.0).
It is not there in F3.0 mode.(high brightness)
DVI/Component
Different discs.
High/Low lamp mode.
