Possibility to record Digital TV on LG RH 199?
mukas
is it possibile to record Digital TV on to LG RH 199?
I'm recieving DVB-T signal decoded MPEG-4 AVC/H.264 standart.
Thanks for any answers
Broadz
No idea what any of these numbers mean, but as long as your DVD recorder has scart input (and I've never come across one that hasn't) and as long as your digital TV source has scart output (and I've never come across one that hasn't) then you connect the two together using scart, select scart input as source prior to recording, select the correct digital TV channel, and press record when the programme you want to record is about to start.
mukas
Thanks for answer.
Seems that i must use fully wired scart, Digital TV source - Sony 32V4500 with MPEG4 decoder - must be switchted on, but anyway must forget about recording with timer....
Rocky 4K, Creed 3 and boxing movies, Shazam 2, 65 trumping Jurassic World Dominion, + Picard & Mando
