thequeenscheese
Hi i dont know iof this will help but a while ago i had an issue with 2 thing the first was poor signal after some time on the blower with sky they got me to move the cordless phone main base and other phones at least 4m away from the box and their was a major improvement with the signal and no more pixelation, the 2nd was when i 1st got the 1tb box as a replacement to the old amstrad i found out about anytime (roughly came out the same time) but on plugging the box into the router after a while it froze up, the second box later did the same, so for the 3rd i didnt bother plugging the router in and kept the old anytime not had an issue since...
Until now where ive had a lot of no signal errors and missed recordings not sure if its cos ive had the faceplate of the wall bcos there is a fault on the seperate phone socket, or if it is because the box is getting hot in the area where the sat cables screw into the back and they are actually fairly hot i was told by the engineer that there is not heat issues with these boxes as they have dual fans and better tech, any1 cast any light?
also on a good note for these boxes the picture (for me anyway) is 100times better to the extent that none hd looks better than hd on the old amstrad box its crisp clear as a bell, i just hope this isnt the start of a gremlin in the box..
