Positioning of 'home cinema' speakers - how high off the ground?
Discussion in 'Home Cinema Speakers' started by Fatman, Jul 28, 2005.
  1. Fatman
    Fatman
    Apr 4, 2004
    125
    16
    Hi folks. I'm about to hang speakers on the walls of my new living room. I've wired cables for centre-rear and surround left/right but for now I'm only going to use rear left/right (in addition to front centre and front L/R, of course). I'm using Wharfedale/NXT flat panel speakers as 'make do' equipment for now, but am thinking of replacing them better later on. How high off the ground should I be mounting the flat panel speakers?
  2. ArsoN
    ArsoN
    I think most people would agree that "wherever sounds best" is the ideal place, but, as far as I know, THX gives rough guidelines of "about 2-3 feet above ear level, to the sides of the listener". From what I've seen, most guidelines are fairly vague, so I guess you just have to wing it.
  3. pwood
    pwood
    Dec 6, 2003
    2,570
    Central Scotland
    +163
    Just above ear height would be my suggestion. Plenty of filler and a tolerant partner would be my other suggestion :D
  4. oconnpad
    oconnpad
    Nov 29, 2004
    260
    +4
    I think there is loads of advice out there about this, my fronts and surround-backs are floorstanders so not much i could do with them.
    My surrounds aren't floorstanders so i put them at my ear level when i'm standing (picture attached). why i put them hear was partly because of the quote from the dolby site which i've included below
    Ideally, your front speakers, high-frequency drivers, or tweeters should be positioned at ear level (when you're seated). Our recommended height for the surrounds is above ear level, as soundtracks are likely to be optimized for that location.
  5. demonhale
    demonhale
    I have a free software for speaker placement at my site
    All I need are feedbacks
  6. spickee
    spickee
    May 8, 2001
    240
    MK
    +5
    I have a bit of a quandry, my centre speaker is actually on the floor and is ont a floor stander, more designed to sit on the telly.
    I would have to buy or make a stand for it to go on for ideal placement.
    Would it be possible to use a second centre speaker mounted above the screen at ceiling height wired in parallel or series, depending which is better for the amp to fool the ears into thinking the sound is in the middle of the screen or would this probably confuse matters further.
    For me in the ideal listening position the placement is fine but for the person offcentre its not so good. Any suggestions?
  7. demonhale
    demonhale
    You could do parallel connection, best to still position it centered still...
    All you need to do to help people sitting offset you is to widen the sound stage...
    Position the left and right, rear and front speakers to point outwards... (make sure the distance from wall is a little spacious...
