Positioning of centre
david230
Hi all,
I have a new tv coming shortly and at some pont I'd like to add a centre speaker to my system and eventually rears. The problem I have is my limited options for where I can physically mount the centre speaker. I wont be able to mount below the telly as this will be almost on the floor. The only alternative would be to mount it above the tv but would this be a bad idea??
The speaker will be quite a bit higher than me at my listenining position, well at best it will be just above my head.
rhino2k
will be fine above tv mate, if you can angle it down slightly it will improve things.
i have may speakers totally offset to the tv and with my auto setup on the av amp it sounds like they are in exactly the right place :eek:
it's quite bizzare :D
