Positioning centre speaker?
Discussion in 'Home Cinema Speakers' started by Preston Albert, Apr 28, 2007.
  1. Preston Albert
    Preston Albert
    My TV is wall mounted above my fireplace and I am having trouble finding room for a Centre speaker. (The mantle is narrow) One option is to place it above the TV (Which puts it quite high) and angle it down somewhat. The other option is to go to a smaller centre speaker from the same company but different series from the front speakers. (Mission V63 and M3c1i as in previous thread.)
    Preston
  2. Henryslater
    Henryslater
    Oct 11, 2004
    170
    +8
    That should be OK. If you think of a triangle between the centre and the L & R speakers then that is roughly where the 'sound' will appear to come from.
    (I would assume that your L & R speakers are below the tv?)
