LittleNipper
I'm about to build my baffle wall. And to be honest, I don't know the best position for these subs.
As you guys know more about subwoofers than I do. I thought I would ask for a "gut" feel on this, because i can't position, measure and then re-position as required.
They were purchase via this thread (500 w x 780 l x 170d sealed) :-
www.avforums.com
The spec for the speakers are :-
rockfordfosgate.com
The LCR are JBL 3677's with L & R slightly toed inwards. The baffle wall will prob. be constructed :-
2:35 AT Screen 3.2m x 1.4m
Room 3.6m x 4.9m ( will be treated ).
Baffle Wall Construction :-
Ply ( 9mm min )
2.5mm Techsound
12.5mm Plasterboard ( Blue stuff )
20-30mm diffusion / absorption to resolve issues with sound bouncing back of AT screen.
So, my questions are (answer as few as you like):-
1. Position A or B or C.
2. At they are 1 Ohm speakers, run them all together ( so 4 Ohm ) or as two sets of 2 Ohm. ( A Trinnov 16 will be controlling them ).
3. How much power (amp) do I need ?
I do have some other subs ( to be placed at rear of the room ) that will go down to 22hz. I don't want any lower ( ATM ).
For Sale - Bespoke home theatre speakers.
Home Cinema Subwoofers (passive, Rockford Fosgate). Condition is "Used". For Sale are 25 high quality Custom built Subwoofers that were part of a high end home theatre installation in central London designed by Prestige Audio. As it was built into the stud wall, it has brackets screwed into the...
Power 12" T1 Slim Single 1-Ohm Subwoofer | Rockford Fosgate ®
The Power T1S1-12 is a slimline 12" subwoofer designed for spaces where traditional sized woofers will not fit. Features a single 1-ohm voice coil for simplified wiring configurations.
Ply ( 9mm min )
2.5mm Techsound
