Position of impedance switch?
Discussion in 'Arcam Owners' Forum' started by berrg, Jan 19, 2005.
Tags:
  1. berrg
    berrg
    :rolleyes: I have found a disagreement between handbook and the rear panel of AVR300. In the handbook the position for 4 Ohm is when level is UP, while on the backpanel it is printed 4 Ohm when level is DOWN. Can you provide me with the correct position?
  2. johndon
    johndon
    Feb 3, 2002
    1,975
    63
    +108
    AFAIK, it's an error in the manual, the back panel is correct.
    John
  3. berrg
    berrg
    Okey, thanks :clap:
