Position Help ?
Discussion in 'Home Cinema Speakers' started by michaelk, Jun 10, 2002.
  1. michaelk
    michaelk
    Hi All,
    I've a bit of an odd shape room, and I'm trying to decide where to place speakers.
    At present I'm looking at a Denon A11SR and Denon 3800 DVD player.
    Speaker wise i'm looking at B&W or Mission. Possibly more towards Missions as they have the wall mounted dipoles.
    My question is where to place the rear speakers, and with an odd shape room, is it better to go for di-poles or standard rear speakers. I was also thinking about a 7.1 set up ? maybe 2 pairs of dipoles one each on wall A,B,C and D.
    Any pointers in the right direction would be greatly appreciated.
    Many thanks
    Michael
  2. petrolhead
    petrolhead
    Mar 29, 2002
    4,822
    87
    Newcastle
    +120
    How abouth this:
    Use 2 x DiPole for l & R Surround and 1 x DiPole for the rear
  3. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,629
    United Kingdom
    +2,233
    For Dipoles to work well, they need to be placed with the "null" of the speaker facing the listening position, ideally either side of this listening position. You need to experiment but try one dipole on the wall where the letter A is and the other on the wall just past where the letter C is. I wouldnt use a dipole as a rear centre stick with a monopole speaker and put that in front of the letter B.
    You can use two monopoles as rear centres and have them as close together as possible, THX Ultra 2 specs now recommend this and it works well, does in my setup.:)
    Its worth experimenting with different speaker positions, angling them down etc.
    cheers
  4. michaelk
    michaelk
    Many thanks for your replies. At least now I've a good idea where to place my speakers. I think I will go for the two di-pole for the left and right and either one or two monopole for the rears.
    Just out of interest should the all the speakers be at roughly the same hieght ? I'm guessing ear hieght ?
    Michae
  5. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,629
    United Kingdom
    +2,233
    Dipoles should be about 2 feet or so above head height. In my system the rear centres are about a foot higher than the dipoles but angled down towards the listening position. Again, its worth experimenting with what sounds best in your room. Quite a few other people have all their surround speakers at the same height though.
  6. petrolhead
    petrolhead
    Mar 29, 2002
    4,822
    87
    Newcastle
    +120
    My advice is aslo to experiment. Althogh Dolby make pre-defined suggestions I believe that we all have different tasts and hearing and only by messing around and testing can you achieve the best solution for you.
    Give yourself a leat a day to do this as you will find there are many permutations.
    Good Luck
  7. uncle eric
    uncle eric
    Michael,
    While I'm not really a fan of 'in ceiling' speakers', I think in your case, (provided you have access to the upstairs floorboards) three speakers as positioned would work well for you.
  8. stranger
    stranger
    small point but the missions are bipoles.
