thestorm
Established Member
Hi all
I have 4 questions. Please can you help?
1.
I am renovating a larger room in the house and turning it into a home cinema room.
The dimensions of the room are 27ft long, 13ft wide and 10ft high.
On one side of the room in the centre there is a chimney breast, it is 167cm wide and 30cm deep.
(pls see attached pic)
Would a SL speaker be suitable next to the chimney breast? as this is parallel to the listening position.
do I pin it against the side wall or position it next to the chimney breast so the output of sound-waves do not rebound from the chimney breast.
2.
I was considering getting the Monitor Audio Bronze FX speakers for SL & SR
Bronze FX
Which mode should i keep them on ? Dipole or Bipole?
3. how high should the SL/SR & SBL/SBR speakers be from the floor?
4. When I do get the TV, where do i position it? centre of the wall or at eye level? The size could be 65 or 75"
1.
2.
Bronze FX
