Ports at back of desktop
Discussion in 'Desktop & Laptop Computers Forum' started by sswf224, Apr 17, 2018.
Tags:
  1. sswf224
    sswf224
    Nov 3, 2010
    I have two ports at the back of my desktop and wondered what they are:-
    One says eSATA
    The other has a like a "D" (without the quotes) or P
    Can they be used for a second monitor ?
  2. DavidG1
    DavidG1
    Jul 5, 2016
    175
    West Yorkshire
    +28
    eSATA cannot be used for a second monitor it is used for connecting an external SATA drive. The other D connector may be a 15 pin VGA connector in which case it can be used for a monitor, there are other D shaped connectors though, typically serial ports but these are uncommon nowadays. It could also be an HDMI connector or DisplayPort. If you post the make and model or a screenshot of the connectors we can give more definitive advice. Whether they can be used to support a second monitor depends on the hardware configuration of the computer, so again without more information, make, model etc it isn’t possible to say. With some models if you have a dedicated graphics card the on board graphics are disabled or at least have to be switched on in the BIOS
  3. sswf224
    sswf224
    Nov 3, 2010
  4. DavidG1
    DavidG1
    Jul 5, 2016
    175
    West Yorkshire
    +28
    The other black port is indeed a displayport (which can be used for a monitor) and the other is a (purple) printer port.
    If the back panel has an additional VGA port then it is likely you can use 2 monitors
  5. sswf224
    sswf224
    Nov 3, 2010
    Many thanks for your help - by other black port I am assuming you mean the lower right hand one.
  6. DavidG1
    DavidG1
    Jul 5, 2016
    175
    West Yorkshire
    +28
